Old 08-03-2006, 05:18 PM   #1
horrible gas mileage.. wtf? 86 tII omni
My Ride: omni
Engine: megasquirted 2.2
i usualy get 20 or so mpg out of turbo omnis, but this one is getting 12 or so... its pretty rediculous especially considering how expensive gas is now.. a/f gauge is blue under any throttle around town, green/yellow at wot.. no black smoke out of the exhaust. fuel pressure is 50, injectors are +20
any suggestions on where i should start? i cant afford a 12 mpg 4 clyinder heh
saw wave analog is offline
Old 08-03-2006, 05:38 PM   #2
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
50psi is seriously high for +20's.. Are you running a computer that supports +20's?
Una is offline
Old 08-03-2006, 05:44 PM   #3
Feedback: (32)
What calibration are you running? Codes?
tryingbe is offline
Old 08-05-2006, 04:27 AM   #4
My Ride: omni
mp stgII no codes, and ive always run 50 on these injectors and got 20 or so mpg
any less than 50 and i go too lean for comfort at 20 psi
Old 08-05-2006, 05:39 AM   #5
My Ride: 1986 GLHS #126
Engine: stock
if you have not changed the fuel pressure, the injectors, or the calibration then i would suggest you give the car a fresh tune up: new plugs (go with the stock ones gapped to .032"-.035", the stock 12 heat range will yield better fuel economy than a colder plug), new cap and rotor, new wires unless those are relatively new, and check your base timing once all the new parts are installed.
other causes could involve: slipping clutch, leaking fuel, vacuum leak, dragging brake pad, poor aligment, worn wheel bearings.....lots of other causes so start w/ the easiest, a tune up.
i have +20's and a 3 bar TU cal base f.p. set to 48 psi....my omni always gets over 20 mpg average so if you're at 12 then you do have something wrong. good luck.
Marcus86GLHS is offline
Credit Card | Credit Reports | Secured Loans | Personal Injury Lawyer Los Angeles | Credit Counseling
Page generated in 0.52865 seconds with 13 queries
