Old 08-04-2006, 02:25 PM   #1
Oil in exhaust manifold -- bad rings?
My Ride: 1985 Omni GLH Turbo
Engine: 2.2 TI
Hey, TDers --
The other day I got my car back together using a used engine and used stock turbo. Soon after starting, it began smoking like mad. I figured, okay, bad seal on the turbo as the engine was reportedly in great condition with only 47k on it.
Now it's been a few months (had a kid, slowed me down a bit). Today I pulled the turbo off. There's no oil in the intake hose, which I assumed there would be (someone told me that was a sign of bad seals). However, there is significant oil residue inside the exhaust manifold. Could that also be caused by a bad turbo? Or are my rings most likely shot?
I'm new to turbos, and not sure if oil could be sucked back through the exhaust -- I'm guessing not.
I haven't tried a compression test. I'm hoping to do that later today.
Ugh.
Andy>>
amiller320 is offline
Old 08-04-2006, 07:50 PM   #2
Engine: 2.2 TI
Tested compression -- all appears to be good. 140-150 all the way across.
So, I'm still hoping it's the turbo. Hopefully tomorrow I'll be able to get the new one on.
Will report back.
Old 08-04-2006, 09:58 PM   #3
Used motor & used turbo You're playing with fire there!
DaytonaTurboZ is offline
Old 08-04-2006, 10:05 PM   #4
My Ride: '89 Daytona Shelby
Yeah, they leak on the exhaust side only too.
puppet is offline
Old 08-05-2006, 10:04 AM   #5
Engine: 2.2 TI
Yes -- buy very cheap fire! This was intended to be a low-cost build-up for casual driving.
Are you referring to the turbo? I assume so. That's relatively good news.
Loans | Loans | Loans | Loans | Mortgage Calculator
Page generated in 0.44060 seconds with 13 queries
