Old 08-26-2006, 10:11 PM   #1
know your 3bar
Images: 10
for anyone who's been paying attention to my plight over the last two months... the car has been god awful rich and just plain sucking out... friend of mine solved the problem tonight. they put the same gm 3bar into a turbo civic and messed the car up... starting searching the net and found that on a gm 3bar, part #12223861 the 5v and ground are swapped... so instead of a=5v, b=signal, c=ground... it's a=ground, b=signal, c=5v. this is a very important piece of info to know.
ps. oh my god is my car fast... gone driving, ian
MESTWHT is offline
Old 08-27-2006, 12:57 AM   #2
Hmmm, you've got a weird MAP. The Turbo 3.8's have the wires in exactly the same spot as our cars.
Old 08-27-2006, 01:33 AM   #3
Images: 10
that's why i didn't try this sooner... i checked the wiring diagrams for the 3.8 gm map and it was deffinetly the same... then my friend found this page... i guess it must've been a production error or something... just put 200km on the car and i'm frigin' thrilled with how it runs, can't wait to see what it does on the dyno
http://forum.aempower.com/forum/inde...opic=17693.new
MESTWHT is offline
Old 08-27-2006, 08:01 AM   #4
My Ride: '89 Daytona Shelby
This should have thrown a code.
puppet is offline
Old 08-27-2006, 08:43 AM   #5
Images: 10
no codes... car was showing 1" of vacuum at idle... which sadly, is in spec for the 3bar, it also never changed, so whether it was at idle or wide open, it was giving the amount of gas it would based on 1"hg. either way... i promise you my car is fixed... little bit high idle, but someone told me it's likely cause of the s60 cam
MESTWHT is offline
Old 08-27-2006, 03:24 PM   #6
Wow, well thats good to know.
As for high idle, usually S60 cams is supposed to give you a bit of a lumpy idle, and the vacuum is definately lower over a stock cam.
Old 08-30-2006, 03:11 PM   #7
My Ride: 86' GLH-s
Engine: 2.2 Turbo
According to the site below, our connectors are the same as the "new" gm 3 bar map; A=ground, B=signal, C= 5-Volt.
http://autorepair.about.com/library/...s/bl306lib.htm
snattsas is offline
Old 08-30-2006, 03:36 PM   #8
I've been looking at the info here and searched the rest of the forums in here too, but in order to use a 3 bar you need the separate CAL right?
88_Pacifica is offline
Old 08-30-2006, 03:47 PM   #9
My Ride: 1993 Dakota
Engine: 3.9
I have the info about switching pins written down on my computer on a post it note because someone told me long ago I would have to switch some wires and notch the connector.
ACR Turtle is offline
Old 08-30-2006, 03:55 PM   #10
I have an 87 GN and I know that the aftermarket MAP's are 'touchy" anyway. Are you using it with the other CAL?
Old 08-30-2006, 04:07 PM   #11
Yes, you need a custom cal to run a 3bar map.
Old 08-30-2006, 10:10 PM   #12
Engine: 3.9
Here's what I have written down:
stock MAP is:
A=5v
B=signal
C=ground
3 Bar MAP is:
A=Ground
B=Signal
C=5v
A,B,C are on the connector for those that don't know.
Old 08-30-2006, 10:14 PM   #13
My Ride: 1987 Daytona ShelbyZ
Engine: 2.2 T2
i just plugged my 3 bar map in after notching the conecctor. i got it for an 89 turbo trans am.
Norm
overboostperformance is offline
Old 09-01-2006, 02:24 AM   #14
My Ride: 89 Daytona Shelby
Engine: 2.2 Turbo
What is the pin out for a 2bar? dodge
Mike_shepard is offline
Old 09-01-2006, 02:31 AM   #15
My Ride: 86 Lazer-89T2 power
Engine: 89 2.5 T2 built
The GM 3 bar is wired the same as the 2 bar Mopar sensor, got 1 on my car. Didn,t change any wires to do it.
ButchSuppe is offline
Mortgages | Moneygram | Advertising | Credit Cards | Php Scripts
Page generated in 1.01327 seconds with 13 queries
