12-04-2006, 11:33 PM
No idiot lights after fooling around with Map
My Ride: 88 LeBaron Coupe
Engine: 2.2 T1
Help needed. I was having stalling off-idel problems with several codes (13, 14, 15, 24, 47). I had a spare MAP and cleaned it out with electronics cleaner spray. I plugged this "cleaned or ruined you pick" MAP in and it would not start. I put the original MAP back in and it would start, but no check engine light or low oil light in the dash. Nothing at all. Any ideas greatly appreciated. I have a parts car with an ECU in it. It is an auto turbo 88 car, same year as mine, but mine is a 5 speed.
Getting worried I fried something.
I tried removing the ground cable for 15 minutes, no change.
12-05-2006, 02:06 AM
More info
Engine: 2.2 T1
I pulled the battery and un-plugged the computer cables. The connections were dirty and had a little green powder on them.
I cleaned these connectors and blew them out with a little compressed air.
Re-installed everything, no change.
I replaced the TPS today with a new unit, nothing different.
I ordered a new MAP, it will be here this week.
I think next I will swap in the other SBEC I have from the auto car and replace the map. I will remove the battery cable before I do anything though.
12-05-2006, 02:32 PM
Engine: 2.2 T1
Wah, nobody loves me! I am losing it over this check engine problem. Keep me grounded please. My next trick is to send the SBEC to FWDP for a new cal. Who has done this?
12-06-2006, 12:26 AM
Engine: 2.2 T1
It sat for about 3 years. I am resurrecting it. I put the motor from the auto donor in there and I am still working out the bugs.
12-07-2006, 05:15 PM
My Ride: 95 CTD, 89 Spirit TD
Check your fuses.
12-07-2006, 06:02 PM
Engine: 2.2 T1
All fuses are good to go.
12-08-2006, 12:34 AM
Engine: 2.2 T1
I replaced the MAP. I also cleaned the ground at the fuel rail. Everything seems better. Still getting a MAP code though. Not sure what to think about that. Vacuum hoses all see fine.
12-08-2006, 04:07 AM
So you are or aren't getting a check engine light?
12-08-2006, 10:37 AM
Engine: 2.2 T1
Hey all,
The check engine light started working again last night after cleaning the fuel rail ground. The low oil light is working now too. I get codes with the flashing light.
I found the SMEC plug pin-outs and checked for poor ground there. The pin-out noted that the grounds were all referenced to that point. So, cleaning that with a little sandpaper seems to have helped the light work again. I have a on again/off again relationship with my SDS and if the car sits for several days, I get no speedo for a little while. I think that may be driving the computer crazy.
12-09-2006, 08:52 AM
#12
Are you getting a code for the SDS? If not then I would say it's your speedo cluster itself.
12-09-2006, 10:49 AM
#13
Engine: 2.2 T1
I am pulling the battery cable every time I open the hood any more. But, I do get the SDS code 15 when the speedo goes quiet. Also, even with the new MAP, I get a map code now and again and have a less than satisfying idle. It idles with a little stutter. I thought it was the hall effect sensor, but that replacement did nothing. I am going through the whole vacuum system this weekend looking for leaks. I think I will just replace everything with a manifold and see if that helps. My only previous experience with these cars was a 1984 2.2 E-Class TBI car that I owned in the late 80's. This is a different world as far as power is concerned.
Unfortunately, I have never had this car running completely right. I pulled it from a field in eastern WA where it had sat for several years with inches of dirt on it and the spark plugs and air box removed. I never even tried to start that motor, but I did turn it over and saved it for a possible core.
This was my little brothers car. He was killed on a motorcycle in 2004. It is a sentimental project, hence the fretting.
12-17-2006, 03:51 AM
#15
Engine: 2.2 T1
Update!
I replaced the hall effect sensor in the distributor and all if the non-PCV related vacuum tubing. I was getting a code 54 as well as the 12 and 13.
While in there, I added a Grainger valve and set it for 11 pounds. Now I am starting to see why there are web sites devoted to these cars. What a hoot!
All seems better now. No stalling and no check engine light when it is not supposed to be there.
Thanks for all the support!
