Old 01-12-2007, 01:44 AM   #1
little spark
My Ride: 89 Shadow
Engine: 2.5 turbo
ok i got the motor back in for the 3rd time in three months and now i have very little spark for some reason.
when i timed the cam it was in compression then it jumped right were it needs to be. but i know that tdc with the cam is not at the stop point. it is supposed to be in the resistance point. i had this problem along time ago and i put the cam 1/4 turn off and for some reason it started.
the cap is good the rotor is good the coil is good the hep is good i belive. the car ran before i pulled the motor this recent time.
only changes were non a/c bracket and cleaning and changing gaskets and seals and painting things.
i am very confused and i need this car running by tomorrow. any suggestions?
Moparbishi is offline
Old 01-12-2007, 02:19 AM   #2
My Ride: 89 Shadow
Engine: 2.5 turbo
just took a compression reading 150 across the board
Old 01-12-2007, 02:57 AM   #3
My Ride: 89 Shadow
Engine: 2.5 turbo
thank you very much force fed mopar you helped me alot
problem solved
Debt Consolidation | Myspace Backgrounds | upside down text | Cell Phones | Anime Episodes
Page generated in 0.89195 seconds with 13 queries
