07-12-2007, 07:47 AM
#17
My Ride: 1986 Dodge Omni GLH-
is the little pushrod under the steering column straight & not bent? if it's bent it won't give full power to the ignition/starter wire causing it to not start intermittentantly. just a thought that's an easy check.
i'm having the same problem right now to though, only it never starts. brand new (reman) starter only lasted me 1 week. it sounds like the starter solenoid makes the usual loud CLICK when i crank the key, i've checked the pushrod, yellow wire has 12v underdash, big wire at starter has 12v and seems to be grounded just fine. couldn't test the little wire at the starter, no one was home to crank the key last night. thoughts?
