07-10-2007, 09:03 AM
overboost problem
My Ride: 86 Omni GLHT
1/4: 11.900
First off the car is an 86 omni with an 87 turbo 2 40s 3" exhaust ported everything, with 3 bar. OK well I just got my new custom cal, installed it took it for a test drive and it won't build boost. They cal shouldn't even have overboost. The car drives fine until the turbo starts to build boost, then it goes into that limp mode thing where it shuts the injectors off until you let off the gas. it drives normal in vac, but as soon as the boost gauge goes to 0 it shuts down. The weird thing is my FWD cal does it also. Car runs good with my 2 bar cal, so I can only think something is wrong with the Map sensor, but its brand new MSD. The only codes it throws are 35,36,37, and 45 all are normal exept 45 overboost. Has any else had this problem? Any suggestions?
