07-11-2007, 10:07 AM
Help me double check my PCV system
My Ride: 86 GLH-T/92 Typhoon
Engine: 2.2L/4.3L AWD turbo
Ok, I'm blowing oil out the dipstick, the oil filler cap, and my newly installed rear main  . The motor has about 17k miles on it. Here is my setup:
From the valve cover, it immediately goes into a T. The right line goes into a catch can, and then into the turbo inlet pipe (non pressurized). The left T goes into a check valve that is closed under boost, then into the intake manifold (as well as the MAP sensor, AFPR, ect). Is this correct? I guess maybe my check valve is busted, but other than that I'm completely lost
Thanks for any help
07-11-2007, 01:17 PM
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
if you're blowing oil out of the dipstick tube you've got some blowby issues.
07-11-2007, 02:14 PM
Yes, my check valve is actually PVC valve.
07-11-2007, 11:43 PM
My Ride: '89 Daytona Shelby
Your CC isn't connected right.
Should be a line from the VC to one nipple on the CC. The other nipple on the CC gets the "T". One side of "T" goes to fresh air intake the other side gets the PCV valve and goes to the intake mani.
07-14-2007, 01:36 AM
Yeah I know, but It's just fits underhood better that way. And that wouldn't cause this problem, would it?
07-14-2007, 10:37 AM
Well, here's the thing. The CC is supposed to separate oil and debris from the gases coming out of the VC before entering the engine. That's their whole purpose. That is why the CC should be the first component in the chain. Gases will have to go through that chamber first.
Your hook-ups will not utilize the CC until your in boost "and/if" the PCV valve is working correctly. That is to say if you have another draw on the VC while in boost. If not, you may as well remove the CC cause it's not even being used.
It shouldn't matter where or how it fits under the hood. The proper connections are just a matter of hose routing ... not so much CC placement. Well, within reason anyway. You wouldn't want the CC in the backseat if you get my drift :P Keeping the hoses large and short is the best.
07-14-2007, 06:32 PM
I understand that, but that would just cause me to burn oil, and not to be blowing oil out the dipstick, filler, and rear main.
07-14-2007, 08:20 PM
I didn't say it would ... just that you have it connected wrong.
(You asked "Is this correct?" in your first post.)
07-16-2007, 12:40 AM
#12
Yeah, that's what I'm afraid of. I'm scared to do a compression test...
07-23-2007, 02:55 PM
#13
Ok, well I finally got the guts to do a compression test, and I'm happy. She has 120 across the board (may seem low to some, but I am at 1 mile of altitude). Next setup is re-re-double checking the PCV system
07-25-2007, 01:45 PM
#15
My catch can is vented to the intake before the turbo. Not sure how it would work if it wasnt.
