08-04-2007, 03:12 AM
High Idle on my 86 GLHT
My Ride: 86 GLHT
Engine: 2.5 CB
High Idle Problem!
86 GLHT with built 2.5 and t3/t4 turbo. 46 mm tb, 88 electronics with MP computer and 20% injectors. 50 psi fuel pressure. 3" exhaust -no Muff. Vacuum block with lines to the map sensor, BOV, FPR and Wastegate actuator. Checked the AIS, and TPS.
I read all about the AIS on the sticky but still cannot get the engine to idle below 2000 rpm. The idle adjustment screw backed all the way off didn't change the idle at all. No vacuum leaks and the engine starts well. New PCV run right to the 1 piece intake hard line. I can get the idle down but have to retard the distributor a lot, and then as soon as I try and set the timing (CS unplugged) and advance the distributor the idle goes up again.
This has got me stumped as I have been working on these cars for many years. I thought the timing is off 1 tooth, but everything lines up correctly so I didn't change it.
I posted this in urgent as the big Mopar meet is tomorrow and I am having this problem.
Anyone got any ideas???
MOPARMANIAC
