08-13-2007, 11:57 PM
Engine removal
My Ride: 1989 Lebaron GTC Vrt
Engine: 2.2 Turbo II
HI, I have a 1989 Lebaron GTC TII and I have to pull the motor and trans. Is it better to pull it from the bottom or through the top?
Thanks
Ken
08-14-2007, 12:07 AM
SHELBY 16V !!!
My Ride: Lots of TIII cars:-)
Engine: 16V TIII
I usually pull mine out through the top. That way you dont have to pull the K-frame. You want to use an engine leveler though.
~Jackson~
TIII GURU
91 Spirit R/T
91 Spirit R/T(GFs hotrod)
08-14-2007, 12:10 AM
So it will fit through the top with the trans attached? I have the car on the lift now and it looked clear to come out the bottom.
Thanks for all your help
Ken
08-14-2007, 09:10 PM
My Ride: 89 Shadow
Engine: 2.5 turbo
ok....... first off a leveler is a must if pulling from the top. 20 $ from pep boys.
it is really easy to drop from the bottom if your on a lift. just put something underneath it like a 4 wheel dolly or something. it really helps to remove the k frame but it is not a must. just makes it a little eisier.
removeing the k fram is easy. remove the 4 bolts and the 6 top strut mounts(or the 4 bottom strut mounts). (wheels of course) and the bolt through the steering coupler.
out the top its easy. hook the hoist up, put the wieght on the hoist and remove all the mounts. then disconnect everything. one note is make the leveler really high on the tranny side. then as you lift the motor drop the tranny. when it come out of the car it will be almost vertical.
08-14-2007, 10:12 PM
ya but i got stick and pulln out the top w. or wo. the trans was a beech so i put it out the bottem and it was ez no chery piker, no kframe removed i just uzed a floor jack an dropt it on the floor thne jackt up the car and pulled out the moter and tranny it went perty good
thne to put in i put it in by pushin the moter and tranny under the car then lowerd the car and used some pry bars and my jack to get them lined up w. the mounts
08-14-2007, 10:28 PM
TurboDodge.com Admin
My Ride: 87 CSX
Engine: 2.2(135) I4
^Dont attempt this process, stick with Jackson's guide... less likely to screw yourself or something else up
Clayton ~ Forum Admin
--Design A TurboDodge.com Shirt contect, Click here-- --Free TURBODODGE.com decals, Click Here for details!--
1987 Shelby CSX #674
FWD Mopar Club of Oklahoma Forum!
08-14-2007, 10:32 PM
My Ride: TIII R/T
Engine: 2.2L TURBO III
cherry picker, chain, take the hood off and get it all apart first then chain it and hoist it out
08-14-2007, 10:34 PM
My Ride: 87 CSX
Engine: 2.2(135) I4
dont need air tools, hand tools work for me, i dont have a garage... back yard grass  you can rent cherry pickers, I do have this
08-14-2007, 11:13 PM
#12
I did not notice a k frame but I did not take a good look. The car is up on the lift right now, so I could drop the motor and trans onto a cart or I can pull it out the top as I have all that is nessary to do that. You must forgive me as I am used to working on old mercury Cougars and they are rear wheel drive. I would like to pull the driveline as I need to do the clutch and maybe the sincrows and as I stated before, the bottem end is gone.
What ever is the best way, I can do it.
Ken
08-14-2007, 11:15 PM
#13
My Ride: TIII R/T
takes a lot longer, ive done it both ways , out the takes minutes comparatively
08-14-2007, 11:18 PM
#14
Sorry, I am missing something, which way is better?
Thanks
Ken
08-14-2007, 11:32 PM
#15
My Ride: 87 CSX
Engine: 2.2(135) I4
i take it from the top with or without transmission, even install it from the top
