Old 08-14-2007, 02:30 PM   #1
Engine Racing
My Ride: 1989 shadow
Engine: 2.5 turbo
need some help, have a 89 shadow 2.5 turbo, engine is racing when you start it, if you push on gas it races harder, changed tps didnt help, found 2 vac lines off replaced still no different, any suggestions? thanks
idahosox is offline
Old 08-17-2007, 06:50 PM   #2
Could be Engine Computer or IAS motor
I had 2 defective Mopar Performance computers in a row that idled too fast. Each time I started it would increase idle in steps till 3000rpm I found a person who burned me some Eproms and his were fine, and one provided the added boost it was supposed to.
JDre is offline
Old 08-17-2007, 08:23 PM   #3
Hybrid Booster
Wow,
Please introduce me to your friend.
Thanks
Ender is offline
Old 08-18-2007, 12:14 AM   #4
Images: 10
dunno if this applies to your situation or not... after i rewired from t1 - t2 i had a couple iffy wires, sometimes when i plug my ecu back in, the car will idle around 2500rpm. i pull the plug, wiggle the wiring a bit, and put it back together... problem solved - till the next time i unplug
MESTWHT is offline
Old 08-20-2007, 12:46 AM   #5
This was years ago, someone who had a website called Berk's GLH, long gone. I don't know if he is reachable, could check my Win98 PC for old mail and ask him. I googled omni glh turbo eprom and found an older topic from this forum that may help DIY Logic Module?
JDre is offline
Record Internet Radio with Tags | Bankruptcy | Moneygram | Just Holden Commodores | Samsung Tocco
Page generated in 0.39718 seconds with 13 queries
