Old 09-09-2007, 11:00 PM   #16
Code 44 is battery temperature is out of range.With all of the testing and parts replacing you were doing I would disregard this code and correct your fuel pressure problem.Fuel pressure is a Basic and needs to be correct for all systems to function properly.After you correct the fuel pressure problem clear the codes,start the vehicle and recheck for any faults.
NAJ is online now
Old 09-09-2007, 11:05 PM   #17
My Ride: 88 2.2 turbo vert
Engine: 2.2 turbo
how do i correct the fuel problem? new pump? sorry, i fix people for a living and not to smart with this car. just getting very aggrivated! argh!!! but i love her and dont want to let her go just yet.
paratender2003 is offline
Old 09-09-2007, 11:10 PM   #18
Go back to page 1,all of the diags were in the post.
So, you are a doctor? Cool, can you fix me,nobody has been able to yet.
NAJ is online now
Old 09-09-2007, 11:16 PM   #19
Engine: 2.2 turbo
ill look again...........nope not a doc.......i do real work as a field medic! having fun now actually.
Old 09-09-2007, 11:25 PM   #20
Engine: 2.2 turbo
ok read the post about the leaking injector and fpr. question.....what about the idle getting better when i disconnect the coolant temp sensor?
Old 09-09-2007, 11:38 PM   #21
Vehicle goes into failure when you disconnect the CTS and runs on a fixed program which sometimes will make the vehicle run better than it does on the non failure program with the problem.
There are basic functions that must be in functioning properly before any other diagnostics can be performed and fuel pressure is one of them.The controller assumes that all basic fuel,ignition and engine mechanical functions are correct to run the engine control systems. Even if this is not the total cause of your stalling problem it needs to be repaired before you can go further.
Without sounding "Corny" here is a medical analogy.If a person has low blood pressure and is bleeding you fix the bleeding and then recheck blood pressure.
In this case your fuel pressure problem is the bleeding.
NAJ is online now
Old 09-12-2007, 09:22 PM   #22
Engine: 2.2 turbo
well here it goes again and i give up! i fd a bad couple wires and also replaced the speed sensor on the tranny and she ran great for about an hr or so. then the idle started to go up and down and she was stalling out on me randomly. and the fuel pressure was staying at 48 psi all the time. i dont know what else it can be. i also tried a computer swap with a friends car and that did not work. my mechanic gave up and said he does not know what else it can be. any takers on the subject or anyone want a car cheep in nc?
Old 09-12-2007, 09:35 PM   #23
I am here as long as you are willing to keep looking.Were any fault codes set this time? When the symptoms occur and the vehicle stalls will it start right up again? Will the problem occur if you just let the vehicle sit and idle?
NAJ is online now
Old 09-12-2007, 10:07 PM   #24
Engine: 2.2 turbo
no fault codes were set and the car will start up again after about a min of "down" time. it will not do it at idle anymore though like it has been doing. oh yeah.....the cade 12 as usual. thanks for helping!
Old 09-12-2007, 10:22 PM   #25
What I need you to do is take a test light with you and a helper.
When the vehicle stalls and will not restart you need to connect the test light to a good ground (Batt -) and see if there is power at the + side of the coil while cranking.
NAJ is online now
Old 09-12-2007, 10:40 PM   #26
Engine: 2.2 turbo
what happens next if there is no power to the coil or if there is power to it? where to from there? ill try it in the am. i have a test light and will try it.
Old 09-16-2007, 03:56 AM   #27
Engine: 2.2 turbo
there is power to the sd of the coil. i just thought of something and dont know if this has anything to do with it. i put some fuel injector cleener in the tank and after that the problems started. anything to do with it?
Old 09-16-2007, 06:08 AM   #28
OK, I reread the entire thread and I would like you to verify a few things.
In the beginning of your thread you said that fuel pressure dropped to 0 when the vehicle stalled and later you said it remained at 48 psi. So just to be sure please verify your test results to this point.
When the vehicle stalls and will not restart ;
1) What was the fuel pressure reading when the vehicle stalled?
2) Was power present at the + side of the coil when cranking when the vehicle stalled and would not restart?
Yes it is possible that bad fuel or additives may damage fuel system componenents but please answer the 2 questions above before I elaborate further or post further diagnostics so I can be sure we are on the same page.
NAJ is online now
Buy PSP | Debt Consolidation | Mortgage Loans | Mobile Phone | Debt Consolidation
Page generated in 0.41208 seconds with 13 queries
