Old 09-05-2007, 11:15 PM   #16
1/4: 13.650
i am currently having this same problem, just put everything back together, car ran and idled fine.....just checking over everything while it was running, car dies. now it refuses to start, just cranks, sputters and dies. hooked up the scan tool, no codes, service engine light flashed a code 25.....use to just have to unhook the battery the last time it did this(over two years ago, last time the car was together)
any suggestions would be great help. Thanks, Paul
Grandma'sCar is offline
Old 09-05-2007, 11:34 PM   #17
TurboDodge.com Admin
moparfwdsleeper's Avatar
My Ride: (2)'87 Shelby CSX
Engine: 2.2(135) I4
Feedback: (34)
Images: 187
replace the AIS relay. That should be what is killing it... Take the relay with you, the auto parts store may need it for reference
Or if you have spare relays, just match the prongs(sp?) up with the same numbers as the original. I had this issue with a 92 sundance with code 25, replaced relay car ran, transmission was about dead though
Clayton
TurboDodge.com Forum Admin
Parting Out: 1987 Shelby CSX #674, Click; CSX Sale or Parts
Payments on shirts due by 12:01AM January 16.
moparfwdsleeper is online now
Old 09-05-2007, 11:41 PM   #18
1/4: 13.650
would you happen to know which one that is?
Old 09-05-2007, 11:53 PM   #19
Engine: 2.2(135) I4
Feedback: (34)
Images: 187
Sorry that was the Auto Shutdown Relay I replaced It's been a long day
Anyways the AIS motor is on the throttle body, it is the bottom sensor/motor of the two on it.
Clayton
Old 09-05-2007, 11:58 PM   #20
1/4: 13.650
i just swapped out all the relays on the driver's side behind the ecu....still nothing, ran all of the tests on the scanner i could, still no leads
Old 09-06-2007, 12:04 AM   #21
Turbo-Baron's Avatar
My Ride: 89 lebaron /shadow
Engine: 2.5 turbo
Images: 20
Im pretty sure it's the HEP
Turbo-Baron is offline
Old 09-06-2007, 02:16 AM   #22
1/4: 13.650
after swapping out the relays, i jumped two terminals on the asd connector causing nothing to happen. checked codes on the scanner and found asd circuit short or something like that. cleared the code and it fired right up. put the old one back in, and it still fired right up.....baffling
Credit Cards | Guitar Lessons | Free Ringtone | Mortgage Calculator | Debt Consolidation
Page generated in 0.35043 seconds with 13 queries
