09-06-2007, 12:25 AM
Mark,
I agree an adjustable cam timing pulley would be a good option for you. However, do you realize how small a couple degrees is? This would be very hard to see without taking some precise measurements. Your absolutely correct that resurfacing the head will retard the camshaft by a couple degrees (depending on how much material was removed from the head). Using the .065 Cometic gasket also retarded the cam timing a bit due to it being thinner than the gasket that came out of the car.
A couple degrees retarded would not make the motor run horrible, but might make it a little poochy at low RPM, and pull harder at higher RPM. Retarding the camshaft just pushes the powerband of the motor upward. BTW - One tooth equals nine degrees. I suspect you had the cam timing retarded by a full tooth.
It is tough to eyeball the camshaft pulley with the camshaft cap parting lines in the car, due to the fenders on the Omni sitting higher than the cam cap parting lines. The easiest way to do this is to put a mirror down there so you can see and set this up properly. Another option is to take the two right motor mount bolts out and lift the motor up on that corner so you can see it correctly. Also be aware that the motor is tilted towards the rear several degrees.
With a sound motor and with a stock camshaft, and with cam timing set correctly, should have about 17-19 HG vacuum at idle @ operating temp. Less than that and you probably have retarded cam timing or retarded crank timing or both.
Good luck,
Originally Posted by markisglh
hi guys just need a little help i have a 85 glh omni i put a new cometic head gasket in it and studs every thing is factory i had the head redone and it was worped so they plained it down so when i got every thing together and i line up the timeing marks the cam timeing looks a cupple degrees off retarded it idles ruff so i advanced it 1 tooth cam timeing and it runs alot better but know it is to far advanced im just trying to get it runing right its such a pain
i talkt to TU and he says that a ajustable cam sprocket will solve all my runing problems just wondering what you guyes think .
thanks mark
