09-07-2007, 07:44 AM
The majority of electronics act up when they get hot due to excessive resistance in the circuit.
Your problem can be Battery,Cables,Starter,Starter Relay,Clutch Safety Switch, Ignition Switch or Dirty,Corroded,or Loose Connections in any of these circuits.
In order to help diagnois properly I need more info, Does it crank slowly or not at all? If it does not crank at all do you hear any "clicking noise" from under the hood? Do all of the lights dim when you attempt to start?
