Old 09-11-2007, 01:44 AM   #1
need some help please
My Ride: 90 shadow
Engine: 2.2 tbi
Images: 9
well, i've been helping a buddy work on his 88 shelby z 2.2 tII(160,000, here's the symptoms
-number 1 spark plug covered in oil,
-smoking under load, or free revving
-comp test 100psi on all cyl's
changed headgasket (lift and slide) no change, we had the oil pan off and looked up at the piston there were no visable cracks from underneath (which doesnt mean much)
there were no problems present untill the head was taken off to fix an exhaust flange leak (head was hot tanked and ex leak was fixed) so long story short we prolly broke something
we were hoping u guys could help point us in the right direction
thanks
tb
tb007 is offline
Old 09-11-2007, 02:55 AM   #2
Did you replace the valve seals?
Old 09-11-2007, 03:02 AM   #3
My Ride: 90 shadow
Engine: 2.2 tbi
Images: 9
no valve seals yet, neither of us have run into and engine that's blowing this much smoke from valve seals, i think that's the next step for us
tb007 is offline
Old 09-11-2007, 03:04 AM   #4
You said you hot tanked the head and if the seals where hard and brittle they may be non-existant at this point.
Old 09-12-2007, 06:37 PM   #5
smok'n
My Ride: 87 SHELBY DAYTONA Z
Engine: 2.2 T2
i was also told that 100psi comp test means that the piston rings are going? when ever i do mine the comp test show's over 125-130 psi?? (87 shelby tona z T2)
lancerman23 is offline
Old 09-12-2007, 07:59 PM   #6
Compression is 100 PSI Minimum with lowest cylinder being within 25% of the highest.Your problem is oil related and oil rings will not affect compression.
Compression readings of 125-130 PSI are fine.
Old 09-14-2007, 01:23 AM   #7
My Ride: 90 shadow
Engine: 2.2 tbi
Images: 9
New valve seals in, the old ones didnt seem too bad, pretty soft, and no cracking. The comp tester is in question, the schreader valve on the bottom was stuck when we first tried to use it, and couldnt find a replacement. We haven't started it because we still have to time it, but it's about ready to start.
the valve guides didnt seem to have to much wear in them either, i don't know where else the oil could be comming from if this isnt it. ???
thanks guys
tb007 is offline
Personal Car Finance | Epson Stylus Photo Printer | Mmorpg | WoW Gold | Debt Consolidation
Page generated in 0.33923 seconds with 13 queries
