09-14-2007, 10:48 AM
My Ride: 89+90 Daytona Shelby
Engine: 2.2 TII, 2.5 TI
No, that's likely code 12 (1 then 2) and 55 (5 then 5). You can look it up, but the 12 is not a problem and 55 is end of test. A speed sensor usually throws a code 15 when it goes bad.
Since you have a digital dash, I'm going to say your speedometer issue is likely a bad solder in the cluster. The digital dashes seem to have that problem a lot. I had a 87 LeBaron that the speedometer would just 0 out on. Redid the solders on the board and it worked fine from then on.
