Old 09-13-2007, 01:57 AM   #1
can i switch the motor
My Ride: 89 dodge shadow
can i switch a 89 caravan 2.5 turbo into the 86 omni 2.2 n/a. im thinking swaping motor, harness and computers and i would have both cars running but with different motor. will i have problem with the axles. thanks for your time. james
waterbird808 is offline
Old 09-13-2007, 11:50 AM   #2
cawcislo's Avatar
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
Feedback: (6)
Images: 4
The engines will fit into the Omni. If you are only swapping the engine the axles would not be getting changed. I do believe the omni axles are not interchangeable with the minivan axles. I'm not sure how difficult it would be to wire in the 89 electronics into the omni. Is the omni fuel injected or carbed?
cawcislo is offline
Old 09-13-2007, 01:24 PM   #3
My Ride: 05 SRT-4 ACR
Engine: 2.4 DOHC
are you gunna put the 2.2 in the mini? that thing is gunna be a pig. The axels are different. And if the omni is carbed you are gunna have to put an electric fuel pump in it and i dont think the harnesses are a dirrect swap either
89daytonashelby is offline
Old 09-13-2007, 05:44 PM   #4
My Ride: 91 Spirit,87 ShelbyZ
Engine: 2.5n/a, 2.2t2
Images: 9
no way the harnesses will swap, omni is LM, mini is SMEC. You would be best getting a GLHS wiring harness and computer, but i dont know how hard they are to obtain. You could grab a t1 harness out of an omni or charger and convert it to t2
this is given that you are TBI, i dont know about carbed cars, I think they require alot more work.
RPMurph is offline
Old 09-13-2007, 11:34 PM   #5
the omni is carb.
i thought the best way for the swap is get a 89 caravan and used the van harness and computer and transfer everything on the omni.
Old 09-13-2007, 11:34 PM   #6
My Ride: 88' Shadow ES
Engine: 2.2L DOHC Hybrid
It's really not _that_ bad, but I deffinately wouldn't recomend it. I have an 86 2.2L carbed mini. Of course it's a 5-spd so it's really not to horrible.
Shadow92_22 is offline
Old 09-13-2007, 11:55 PM   #7
My Ride: 84 Plymouth Turismo
Engine: 89 2.5 I/C TURBO
I put a 89 2.5 Turbo and the Turbo auto in my 84 Turismo..everything from the van went in.. I had to shorten the harness by six feet....Lots of fun and well worth it, check it out here if you like...
Robb www.cardomain.com/ride/2291434
TurboTurismo is offline
Old 09-14-2007, 12:35 AM   #8
well ill guess ill scrap it and just build the van or build my shadow turbos and used omni for grocery shoping. i really wanted to race the omni on the track. ill wait or do more search on who did it.
Old 09-14-2007, 02:22 AM   #9
MEOW!
My Ride: 87shelby charger
Engine: 2.2L TII
Images: 152
ok if you want to do a omni get a 88-90 omni TBI car and the harness's will inter change. with the van harness you will have to rewire the wipers for the omni becuse they will not work but its pretty easy to do.
if you want to use a LM/PM harness one out of a 86 new yorker turbo car will work.. i have done this swap on my 90 omni the 86 newyorker harness was the first to be swaped and it worked great!! and then i got a 89 mini harness and it ran great! couldnt drive in the rain untill i rewired it but it was fun.
hope this helps!!
turbomini is offline
Old 09-14-2007, 01:08 PM   #10
Comon, do it.. You won't regret it.. The wiring is really straight forward.....
Old 09-14-2007, 01:42 PM   #11
hoooo now your raising my confidence. so it can be swap right. the only problem would be the windshield motor wire right.
Web Advertising | Online Loans | Adverse Credit Remortgage | Car Loan | Modded Xbox
Page generated in 0.36393 seconds with 13 queries
