10-28-2007, 10:02 PM
#22
Re: Omni pressurizing crankcase
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
Have you ever experimented to find out exactly how much pressure you need to push the dipstick out of its tube? I'm sure it varies from stick to stick, but expect more than 13 PSI to push it out. I performed the experiment a couple months ago.
Do what was said before--disconnect and plug off that big huge vacuum line from the intake manifold to the PCV valve and leave the other end just sit there. If the dipstick still comes out, we have just ruled out the possibility of intake manifold pressure getting into the crankcase to cause the concern.
*IF* your camshaft timing is correct, and the compression readings are accurate, there is something wrong with that leakdown test because you should be getting much more compression than that. That also means there is something wrong with your pistons / piston rings.
Loosen the oil cap, and let it rest on the valve cover. Start the engine and goose it to about 3500 RPM. Does that oil cap stay there?
