Old 10-28-2007, 11:15 PM   #1
89 Shelby daytona ???????
My Ride: 89 Dodge Daytona
Engine: 2.5L
I just bought an 89 shelby daytona turbo. Let's just start off by saying this vehicle was a mechanics car.... so ya... anyway the car dos'nt run at peek performance but i'm trying to get the turbo running... at idle the car has 15 vac and then if it's in nuetral or full throtal going about 40. it tops out at 5 or 6 boost. I really dont know much about turbo's never worked with them. so if anyone can help me on this... any sugestions would help. thx
kerazyguy is offline
Old 10-31-2007, 11:53 AM   #2
Re: 89 Shelby daytona ???????
My Ride: 73 AMC Gremlin
Engine: 304ci V8
You should post in the regular forums not the shelby forum cause this is a Numbered shelby specific forum and you will have more luck in the "help" forum
sleeperspirit is offline
Old 10-31-2007, 01:12 PM   #3
My Ride: 1991 Shelby Daytona
Engine: 2.5L T2
Possibly gas, my car did the same thing with mid-grade i put good premium gas, and some octane boost in, and it was back to normal.
91shelby is offline
Old 10-31-2007, 08:20 PM   #4
TurboDodge.com Admin
moparfwdsleeper's Avatar
My Ride: 87 CSX
Engine: 2.2(135) I4
Feedback: (33)
Images: 187
Moved to TD Help section from Discussing Shelbys section
on another note this is a shelby section. numbered or not doesnt matter
Clayton ~ Forum Admin
--Design A TurboDodge.com Shirt contect, Click here--
1987 Shelby CSX #674
FWD Mopar Club of Oklahoma Forum!
moparfwdsleeper is online now
Old 10-31-2007, 10:43 PM   #5
Engine: 2.5L
Really? it runs better like mechanicly on premium gas?... or higher octain...??????
Old 11-01-2007, 09:20 AM   #6
You need to run fuel with a minimum octane rating of 91 in a turbo to prevent detonation.If the vehicle detonates the controller will pull timing until it stops.
The octane rating of a fuel is its ability to resist detonation, that is the only reason for running a higher octane fuel,the additive packages are the same in all grades as mandated by federal law. Using a high octane fuel in a vehicle that is not designed for it will cause driveability concerns. Chrysler released a TSB addressing this concern.
15" hg is slightly low,min should be 16",check at a manifold vacuum source to be sure.
Engine mechanical and sealing,external vacuum leaks(big problem on these cars),cam timing,ignition timing will create the driveability concerns you are describing.
Be sure all of your other basics are correct,fuel pressure and secondary ignition.
NO: 14-08-97
SUBJECT: Poor Driveability With High DI (Driveability Index) Fuel
DATE: Nov. 21, 1997
SYMPTOM/CONDITION:
Long cold start times, warm-up sags, hesitations, and driveway die outs. These symptoms are most noticeable and severe at moderate ambient temperatures between 4 - 27 degrees C (40 - 80 degrees F).
DISCUSSION:
Gasoline with a high Driveability Index (DI) can cause the above described symptoms. DI is a measure of the gasolines total volatility, or tendency to vaporize completely. A high DI number is less volatile than a low DI number. Most premium gasoline sold in the U.S. has a higher (worse) DI index than regular or mid-grade gasoline. Use of premium gasoline is NOT recommended for vehicles designed to run on 87 (R+M)/2 regular or 89 (R+M)/2 mid-grade gasoline. High DI gasolines also cause higher emissions for the same reasons they cause driveability problems.
For vehicles that require an octane rating of 91 (R+M)/2, premium is recommended, or possibly required. Using premium fuel with a higher than recommended octane rating is not recommended. Owners who experience fuel related cold start and warm up driveability problems should try a gasoline with the recommended octane rating or different brands of gasoline until they find one that provides good performance.
The octane quality of gasoline is only a measure of its resistance to spark knock. The use of higher than recommended octane gasoline under normal operating conditions does NOT improve startability, idle quality, fuel economy, driveability, acceleration, engine durability, or emissions. In fact, most higher octane gasolines available in the U.S. have higher DI values than regular gasoline. Customers are most likely to experience poor driveability with premium gasoline than with regular.
Some vehicles, such as Viper, Prowler, 5.9L Grand Cherokee, 2.0L Turbo Talon, and 2.0L DOHC Neon have been specifically designed to take advantage of higher octane. These vehicles may have higher compression ratios, and/or more aggressive spark calibrations which provide optimum performance with the specified higher octane. However, other vehicles which are not specifically designed and calibrated to take advantage of higher octane will not benefit from higher octane.
Some vehicles may experience light spark knock in situations such as trailer towing or climbing steep sustained grades. Light knock or "ping" under these conditions is not harmful. However, if the customer is concerned about light knock under these circumstances, the use of 89 (R+M)/2 or even 91 (R+M)/2 premium gasoline may be temporarily warranted. If a vehicle is experiencing heavy spark knock on gasoline with its designed octane rating, this may be an indication of excessive combustion chamber deposits, or some other problem. Combustion chamber deposits can be removed with Mopar Combustion Chamber Conditioner p/n 04318001. Standard diagnostic procedures may help in identifying other potential causes of excessive knock.
Some gasoline marketers may advertise that their premium gasoline contains extra detergent additives. Under provisions of the Clean Air Act, ALL gasoline sold in the U.S. must contain effective deposit control additives. Nevertheless, if fuel injector or intake valve deposits are suspected of contributing to poor performance, occasional use of Mopar Fuel Injector Clean Up p/n 04549613 is a much less expensive way to maintain engine cleanliness than regular use of premium gasoline.
The attached charts (Figure 1 & Figure 2) show the negative effects of high DI fuel as related to customer satisfaction.
If fuel quality is suspected in causing a customers driveability concern, your zone technical office may be able to provide direction on procedures for fuel sample analysis.
POLICY: Information Only
Old 11-01-2007, 12:53 PM   #7
Engine: 2.5L T2
Yeah really , theres a reason chrysler put a sticker in the gas tank fill lid that says premium recommended. Never run regular in these cars!! I would only go with premium +. Mid grade can cause problems as well. Ever since i completely stopped running the mid. I now run 100+ octane. the difference in gas mileage between mid and premium was a couple miles more for me.
91shelby is offline
Old 11-01-2007, 08:31 PM   #8
My Ride: '89 Daytona Shelby
kerazyguy ... sounds like your cam and/or ignition timing is off.
puppet is offline
Current Accounts | Mobile Phone | Mbna | Personal Finance | Hookahs
Page generated in 0.79086 seconds with 13 queries
