12-28-2007, 05:18 PM
Battery wont charge HELP!
My Ride: 89 Daytona Turbo II
Engine: need dyno
Problem:
Battery will not charge by alternator, and will not hold a charge.
Possible causes:
In my mind i think that the wireing circuit could be screwed up or bad between the alt. batt. and comp.
Alternator ios original and could very well be crap.
Batteries could be bad.
What ive already tried:
Slow charging two different batteries in which case i got the same results. Able to charge, but no charge maintained.
Tried revving engine to see if i could see the volts going up on gauge in car. No luck, they jsut remain low around 12-13v.
So most people would say just change the altornator. However if i can avoid it i would like to. Alternators are expensive, and surprisingly kind of difficult in this car (Turbo II Daytona). When the car is running and driving, lights on, w/e it can maintain enough of a charge to stay on... wierd.
