02-04-2008, 02:06 PM
Re: Need help with a 1987 Shelby Z
My Ride: 87 daytona shelby z
Engine: 2.2l turbo
Tha factory "vacuum block" is the biggest POS in my opinion...normally, since yours/my car is 20yrs old, theyre brittle... mine snapped when i looked at it wrong..I recomend an aluminum one from turbos unleashed, or somewhere. Factory it was basically a bunch of plastic tubes running from each part, then they all joined up back behind the intake manifold. As for the wastegate, On mine it runs from the WG, to the WG solenoid, and then to the vacuum block, But I think on my friends CSX, since he has it running to the TB as well, but he also has a boost controller, and I dont. So if you want it hooked up to factory spec, run it to the solenoid, its the middle one on the passenger side fender
