Old 05-06-2008, 09:42 AM   #31
Re: New to Mopar..
Feedback: (29)
Originally Posted by The Pope View Post
BTW I am a mechanical dyslectic and it jacks my IQ to 157 but only in math and engineering, then it murdered my english skills. I will never be able to spell and write well my whole life =P
You're too humble. You are already doing better than 95% of people who type in here.
tryingbe is offline
Old 05-06-2008, 10:16 AM   #32
Re: New to Mopar..
The Pope's Avatar
HA I have over 2,000 posts and I rearrange basically the same words over and over. Every once in a while you'll find words not used often on the forum, even simple words I completely screw up if there ones I don't use over and over. My english skills are a copy machine / cut and past type thing believe me I couldn't pass basic english in College because I couldn't get past a section in the book. Prepositional phrase. People that couldn't speak any english passed the class. But I did win a nation award in engineering, the J.E.T.S. test. I was the engineering rep and did the 18th question in 1988.
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
70 R/T SE Challenger
The Pope is offline
Old 05-06-2008, 11:16 AM   #33
Re: New to Mopar..
My Ride: 1990 Dodge Omni
88-89 Dodge Shadow turbo is the best harness to use for fit, then you need to find the wiring break down to connect it to the car at the 50 pin.
Would other harnesses work also, like a lebaron turbo (1989) harness?
OMNIproject is offline
Old 05-06-2008, 12:22 PM   #34
Re: New to Mopar..
I found a performance computer, not sure if its stage 3 or not. Its originally from mopar with part # R4532132. Said it came out of a 1989 dodge daytona. If you look at it, its got a large connector at the top-middle of the unit and a smaller one to the bottom left of the larger one. What do you think?
Old 05-06-2008, 06:24 PM   #35
Re: New to Mopar..
The Pope's Avatar
I think it is a stock SMEC computer and a reman makes it worse lol. Send it to FWDperformance and get a new one. It is always a good idea to get the for the car and buy a computer for the mods.
Rob Walsh
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
The Pope is offline
Old 05-06-2008, 06:51 PM   #36
Re: New to Mopar..
The Pope's Avatar
they all work with enough cutting and wire moving, the Shadow one just fits best.
Rob Walsh
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
The Pope is offline
Old 05-06-2008, 10:02 PM   #37
Re: New to Mopar..
EvilcowRoland's Avatar
My Ride: '90 Daytona Shelby
Engine: 2.5 I/C T1
Images: 11
If it has 2 plug connectors, it's a SMEC. Those were '88 and '89 computers. Your car currently has an SBEC ('90-'91). But since you're swapping the wiring harness, it doesn't matter what computer system you have as long as it matches the harness. Personally, I like the '89 SMEC best. The SBEC supposedly has some improvements, but I'm just partial to the '89 stuff. There are more stock computer options available to you for '89 (but you can always get a calibration from FWD or TU so that isn't really the best selling point). Anyways, if you use the '89 LeBaron harness then that '89 computer would work, but you should definately find out what engine it came from. There have been numerous posts about computer part numbers around the forum. You should be able to do a search and compare your part number to figure it out. The biggest difference between your car and the '89 LeBaron harness will be in the lighting systems and I believe the power accessories (wipers etc.) Someone more experienced in L-bodies can chime in on what all is different.
EvilcowRoland is offline
Old 05-07-2008, 11:59 AM   #38
Re: New to Mopar..
I know way at the beginning of this thread, someone mentioned that a 89 turbo minivan wireharness would work good, and i found a 87 daytona wire harness 2.2 turbo as well as an 89 minivan one. Would either of these work just as long as if i got a computer to match it?
Old 05-07-2008, 12:58 PM   #39
Re: New to Mopar..
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
The '89 would be easier because it has only one computer.
sittn86 is offline
Old 05-14-2008, 03:31 PM   #40
Re: New to Mopar..
I found a 1989 Turbo Minivan harness and computer for 125 + s/h. Good deal?
Flights | Cheap Flights | Mobile Java Games | Car Insurance | Myspace Comments
Page generated in 0.47913 seconds with 13 queries
