Old 05-05-2008, 08:30 PM   #1
Leaking coolant!!!
My Ride: 88 daytona shelby z
Engine: 2.2 turbo
Im leaking coolant from behind the motor, it leaks almost as fast as I put it in. Any idea what it could be?
Two40s13 is offline
Old 05-05-2008, 08:34 PM   #2
Re: Leaking coolant!!!
My Ride: 87 Daytona Shelby Z
Engine: 2.2 T2
I would say coolant line to the turbo
midnighttoker is offline
Old 05-05-2008, 08:39 PM   #3
Engine: 2.2 turbo
ill check that out, I am in the dark bout it lol.
Two40s13 is offline
Old 05-05-2008, 08:41 PM   #4
Engine: 2.2 T2
I am pretty much too when it comes to cars period ,but I know the coolant line runs to the turbo so thats probably it
Old 05-05-2008, 08:45 PM   #5
My Ride: 1985 &86 Omni glhts'
Engine: 2.5 T2
Images: 14
My guess is a freeze plug.
ol"blue is offline
Old 05-05-2008, 09:09 PM   #6
hotrodguru
dirtyglhturbo's Avatar
My Ride: 86 glh turbo
Engine: t2 2.2l intercooled
you need to contort your body any way you need to to get a visual on the leak. you can't just speculate. use a mirror for hard to see spots. sounds like you should be able to see it if you threw a jack under it, and grab a flashlight, and look for the point of exit.
dirtyglhturbo is offline
Old 05-05-2008, 09:16 PM   #7
Engine: 2.2 turbo
Yea, u had it jacked up and I was under it getting soaked lol.
Two40s13 is offline
Old 05-10-2008, 09:30 AM   #8
Engine: 2.2 turbo
ok turns out its the frost plug. they put a new one in and the compression in one of the cylinders is ****ed up. Something about when the car gets warm it drops dramatically in that one cyl. any ideas? they are gonna look into it monday but id just like to have some idea what it could be.
Two40s13 is offline
Old 05-10-2008, 09:36 AM   #9
hotrodguru
sounds like a possible head gasket or head problem. it may have built up too much pressure in the cooling system, popped your already failing freeze out plug. a leak down check and a chemical headgasket test sounds like its in order. good luck
Old 05-10-2008, 09:39 AM   #10
Engine: 2.2 turbo
damn, I thought it could be that. I just dont want it too be lol
Two40s13 is offline
Old 05-10-2008, 09:43 AM   #11
hotrodguru
never fun. but its really not the end of the world. hopefully its just the gasket.
Old 05-13-2008, 06:10 PM   #12
Engine: 2.2 turbo
well it is the headgasket, it was bubbling or something lol
p.s. If ANYONE is selling a drivers side fender id love to buy it, mines got a dent.
Two40s13 is offline
Best Credit Cards | CreditCards | Credit Cards | McDonalds | Debt Help
Page generated in 0.34370 seconds with 13 queries
