Old 05-10-2008, 05:03 PM   #16
Re: How many miles to seat rings?
Originally Posted by william View Post
It was only piston #1 that melted. It was down about 30 psi on a compression test. I replaced the pistons and rings as a set in all 4 cylinders (new HG as well), they had been pulled from an engine that had been run for an hour or so. I don't know why they were pulled, as it wasn't my engine. The whole thing was only meant to be a temporary fix, but I started to wonder if they might seat after a few more miles and I could run out the next few months as-is until the new engine is finished. No harm in trying I suppose, the black flies are getting bad in the neighbourhood anyway.
a lot of harm in cobbling a car together cuz the typical td owner cant afford to buy a new headgasket so now u gotta tear down the engine and do it right gonna cost you about $100 to do it over again-hg, oil, filter misc stuff- but hey maybe the next time you dont take shortcuts.
allmotor is offline
Old 05-11-2008, 08:49 PM   #17
Dude, head gaskets are like, $30! I don't know anyone who has that kinda scrill!
william is offline
Old 05-12-2008, 07:22 AM   #18
over 50% of the users on this board
allmotor is offline
Old 05-17-2008, 08:48 PM   #19
Man, that means that nearly half of the people here CAN spend $30 on a headgasket! There is more money here than I had ever dreamed!
william is offline
Old 05-17-2008, 09:00 PM   #20
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (17)
Just fired up mine after a re-ring due to a melted piston and they seated right away. Quick hit with the stone hone and was extra careful on reassembly. 0 miles just some hard revs. Probably gonna beat on it tomorrow with some 6-7 psi runs. Crossing my fingers they stay that way.
Come for a dyno run NEW Get-together 2-23-2008 @ 10am
http://www.turbododge.com/forums/f1/...-dyno-day.html
crazymadbastard is offline
Web Hosting Service | 1-high-chair.com | Credit Cards | Xbox Cheat Codes | Mortgages
Page generated in 0.27266 seconds with 13 queries
