05-15-2008, 11:33 AM
Re: Limited boost?????
NORCAL
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
im pretty sure those ports on the throttle body dont have any vacume, they are just there for the evap. to purge into the intake system.
You should put your g-valve inbetween the wg and the compressor housing nipple. The less hose you use between the two the better. Though not so easy to adjust always...
'86 Lan. Pac. 2.2LT2d CB w/ FWDp Eagel Rods, .040 venolias, ARP studs everywhere, ported exhaust mani, g-valved, egt & boost gauge pillar pod, custom cal, TU 4-puck yellow pp, a555 w/ quafie lsd, alum. flywheel, Full 3in mandrel bent exhaust w/ TU 3in SV & OBD2 h/f cat, Magnaflow straight through muffler, Turbonetics t3/t4 .63 ar stage 2 wheel w/ custom weld job to clear head, cummins fmic, KONI adj. coilovers, adj. rear koni shocks, SLH ''11inch. vented rear rotor conversion
