So I thought it a good Idea to Turbo my 92 acclaim the engines from what I can remember as a 1990 Dodge spirit turbo. It started sputtering and dieing goin down the freeway when I pulled over and shut it off I couldn't get it started, I towed it home checked codes its comin up 12, 61, 37, 41 I've read what most of these mean but that doesn't mean I know what or where they are
. Can anyone tell me A which of these codes would keep the vehicle from running, and also Where or what some are.
37 Shift indicator light failure, 5-speed
part throttle lock/unlock solenoid driver circuit (87-89)
solenoid coil circuit (85-89 Turbo I-IV)
Trans temperature sensor voltage low (1995 and on; see NOTE 2)
None of these seem to have anything to do with me?! Its an Automatic and doesnt fit between any of these years? Maybe I'm off on the year of my engine If so Solenoid coil Circuit, or Part throttle lock/unlock solenoid driver circuit. What are these and where?
41* Alternator field control circuit open or shorted
Not even sure what this is
and I know 61 Is "baro" sensor opened or shorted
I have tried 2 diff map sensors and another Baro but virtually nothing changes
I've checked for spark and for fuel both seem to be there.
Any help would be Great! Thanks
