Old 07-11-2008, 11:30 PM   #16
Re: Engine cutting out..
My Ride: 1989 Shelby Daytona
Engine: 2.2l
Images: 6
Yeah, I have tried a few map sensors with no luck.
I don't understand why the fuel pump would cause this problem. I have had the fuel pump in the car for 3 years with a 2.2l engine and this never happened.
Shmiggz is offline
Old 07-11-2008, 11:34 PM   #17
My Ride: 86 Laser XT
Engine: 2.2 turbo
Images: 2
^check your fuel pressure!
Rig a gauge and stick it under the wiper and go for a drive
The fuel pressure should go up 1-2 psi per #of boost!
That will give you a good reading.
Old 07-18-2008, 11:30 PM   #18
Engine: 2.2l
Images: 6
Ok, So I hooked up a fuel pressure gauge to it and it reads 55 at idle and 65 with the vacuum line unhooked. I believe this must be the problem since its 10 lbs higher than it should be. I have an adjustable fpr, but its not hooked up since I need the after market fuel rail. I do have one of those on order :-)
Shmiggz is offline
Old 07-26-2008, 12:22 AM   #19
My Ride: Dodge Lancer
Engine: 2.2 turbo 1
I had the exact same problem on my '86 lebaron GTS. The car ran perfectly fine for the most part but if I opened the throttle all the way or close to it the engine would cut out and the power loss light would flash on for a second but that car is long gone i never did fix it but i still have the engine because it only has like 15,000 miles on a rebuild anyway my current car is an '86 lancer that I bought from my neighbor and he claims he had the exact same problem and fixed it by replacing the distributor. I dont know if thats completely true but I think its definately worth a shot.
I say replace the distributor
NFND is offline
Facebook Proxy | Credit Card Debt Consolidation | Share Prices | IT247 Computer Hardware | Credit Reports
Page generated in 0.37205 seconds with 13 queries
