Old 05-30-2008, 04:40 PM   #16
Re: turbonetics t3/t4 trim 50 goes wrong
My Ride: Spirit R/T sohc
Images: 2
Originally Posted by 1badsrt-4 View Post
It has to bne some sort of wastegate issue. Im guessing its internally gated. So make sure the flapper is opening and closing all the way.
It could be possible, sound good, to good but it's the second time that I checked the waste gate flapper and seems to be seating good;
I'm using av-gas 100/110 oct and something special happened when we use that gasoline, is very easy enough to see if a exhaust leak is on the stuff, because the smoke on the swing valve or turbine wheel or exhaust manifold even in the moffle pipe is white not black, so in my case the turbine housing hole seems to be full sealed.
elchihuas is offline
Old 05-30-2008, 05:30 PM   #17
Authorized TD Vendor
JamesL's Avatar
Are you saying that you are able to make a visual inspection of the puck sitting against the bypass hole with the car running? Try not to get burned. OUCH. Seriously though, drop the downpipe...when its cold get a flash light and apply some regulated pressure to the actuator. Make sure it operates properly and does not hang up. If it appears to operate properly make sure the puck covers the hole completely. Disconnect the actuator, open the valvee put some grease around the bypass whole and then close and open the puck. Did the grease transer all around the puck? The only other thing I can think of is a crack in the turbine housing or a boost leak somewhere else. Do you know how to do a boost leak check?
FWD Performance is happy to provide tech support for products purchased from any vendor. If you can't get product shipped on time or get qualified tech support from your current vendor it's time to do business with FWD Performance. Real Race Products by Real Racers.
FWD Performance, making the genuine investment to bring you a variety of quality products in one stop delivered to your door FAST
JamesL is offline
Old 05-30-2008, 08:19 PM   #18
My Ride: Lancer Shelby
Engine: 2.5T
my turbonetics turbos never had a seal either. I'd assume its a machine-fit. Looks like you need to pressure test the wastegate and piping.
Mystryguy is offline
Old 05-30-2008, 08:26 PM   #19
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (20)
I have heard of leaky turbonetics before and people sealing the backplates with rtv silicone. I would re-assemble and look for the leak. Oil has no business being there either.
I practice what I preach:
crazymadbastard is offline
Old 05-30-2008, 09:42 PM   #20
Shadow's Avatar
1/4: 11.090
Images: 6
What are you using for an oil drain tube?
Shadow is offline
Old 05-30-2008, 10:12 PM   #21
Images: 2
-the inspection that I did was with the turbo down.
-good suggestion or tip talking about the grease.
actually my turbo was leaking air pressure when the first pressure test for the backplate and the compressor housing, it was due to it doesnt have seal.
Originally Posted by tryingbe
Can we get some high quality pictures of your setup?.
:c onfused::con fused::confu sed::confuse d:
Old 05-31-2008, 12:25 AM   #22
My Ride: 89 daytona/85 laser
Pull the the blow off valve and plug the hose and then test it to make sure its not malfunctioning
jim34 is offline
Old 05-31-2008, 12:53 AM   #23
Feedback: (32)
What are you doing for PCV valve?
tryingbe is offline
Old 05-31-2008, 06:01 AM   #24
My Ride: shelby charger 86
Engine: 2.2turbo t1 conv t2
Images: 2
what it seems to be for me is the swingvalve valve is not sealing tite on the housing making a wastegate leak , i would do a boost leak test too
shelbymonster is offline
Old 05-31-2008, 10:22 AM   #25
Shadow's Avatar
1/4: 11.090
Images: 6
When you put the W/G actuator on the turbo, how much preload did you put on the S/V arm? ie. If you take the clip off of the actuator arm and seperate the actuator from the S/V, how far would you have to pull the actuator out to get it on the S/V again?
Shadow is offline
Old 05-31-2008, 11:25 AM   #26
The Pope's Avatar
^^ that could be it. Thing may just be sloppy, just not enough tension on the flap to keep it shut.
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
70 R/T SE Challenger
The Pope is offline
Old 06-01-2008, 12:30 PM   #27
Images: 2
is done, same thing.
an oil catch can
mmhh
around 1/2 " of distance, actually it was too hard have to pull the actuator in to get it on the S/V again.
**well, the conclusion it could be between s/v an s/v actuator.
**and how about the turbo inlet compressor oil??? that isn't normal, nobody told me nothing about the oil.
**the turbo is new only maybe 300 kilometers on it bought it on April.
turbonetics says that sometimes is normal due to high oil pressure on relanti but my oil pressure bomb is almost brand new original Melling and the oil pressure indicator is ok
Old 06-01-2008, 02:06 PM   #28
Feedback: (32)
How is your oil catch can setup?
Any oil in your intercooler?
tryingbe is offline
Old 06-01-2008, 03:14 PM   #29
How does the turbo spin ? and how does it sound, can you hear it whistle when its boosting ?
jim34 is offline
