Old 06-02-2008, 12:29 AM   #31
Re: turbonetics t3/t4 trim 50 goes wrong
My Ride: Spirit R/T sohc
Images: 2
Originally Posted by tryingbe View Post
How is your oil catch can setup?
Any oil in your intercooler?
no oil in the Ic, only in the inlet compressor housing.
the oil catch can-the breathing hole in the valve cover with a rubber tube into a plastic can and another rubber tube for breathing the can of exhaust gas, the hole in the admision was plugged with aviation PRC
Originally Posted by jim34 View Post
How does the turbo spin ? and how does it sound, can you hear it whistle when its boosting ?
the turbo spin soft and smooth no issue with that.
Originally Posted by Shadow View Post
Actually, that's why I asked about your oil drain tube. Ppl who don't know any better use silicone on the gasket and when it squishes it blocks the oil drain and you overpreasurize the bearing housing and it leaves through the seals!
good point shadow, but the last time when the turbo was removed, the oil drain seem to be ok, but why not double check, actually, today I got another garrett swingvalve and tomorrow I m going to put on the t3/t4, good luck for me
elchihuas is offline
Old 06-03-2008, 11:10 PM   #32
Images: 2
yesterday, I put another garrett swingvalve...nothing fu&%$#n happened, I sad
this is the old swingvalve looks good flapper good
this the "new" (on the turbo) garrett swingvalve, once again nothing happened
Old 06-04-2008, 08:39 AM   #33
Shadow's Avatar
1/4: 11.090
Images: 6
What does the car feel like at 7psi? Does it seem like the turbo is spooling and your not going anywhere, or does it seem to make the right power for 7psi boost?
Shadow is offline
Old 06-05-2008, 09:36 PM   #34
My Ride: Lancer Shelby
Engine: 2.5T
What wastegate actuator are you using (brand)? The vacuum line is still removed when you are testing? can you pressurize the wastegate slowly with a low psi regulator and watch it open at said psi? have you pressure checked your intercooler pipes?
Mystryguy is offline
Old 06-27-2008, 03:05 PM   #35
Images: 2
well, after a long long history, I decided to change the .63 a/r turbine turbonetics housing to .42 garrett housing and I got a good garrett wastegate actuator from an 97 turbo eclipse gst.
the spool is working so good no lag, I'm getting psi from 2500 rpm (good for a t3/t4 46 trim a/r 48) and my boost is working so fine 14 psi calibrated with my boost control.
So my turbo issue it was officialy in the past
thank's a lot for all the person who gave me support and thank's Cindy of course for your attention on my case
Old 06-28-2008, 06:52 PM   #36
EvilcowRoland's Avatar
My Ride: '90 Daytona Shelby
Engine: 2.5 I/C T1
Images: 11
Well, as long as it's working now and you're happy with it, that's all that matters.
EvilcowRoland is offline
Mortgage | Debt Help | Online Dating | Finance | Anime
Page generated in 1.06655 seconds with 13 queries
