06-03-2008, 05:24 PM
#20
Re: AC R-12 to R134a retrofitting
You should have put in 24 oz. of R134A (30 oz. x 80%)
R134A is more fickle than R-12. On the old R-12 systems if you overfilled the system it would get colder. R134A that is low or high will not cool efficently and the high side pressure may be running to high, if you do not have a set of gauges to check the high side pressure and the high side pressure is too high you may find out when sitting in traffic when air flow thru the condenser is reduced and it blows out the pressure relief valve.
06-03-2008, 07:41 PM
#22
Ok,sorry,here I go again.
After I put in the last can of R134a,the gauge was still in the blue,just below 30,and the clicking on and off of the compressor continues.I don't see any leaks,but I think tommorow I will take it to get it checked for leaks.I looked up all the symtoms of a bad compressor and my compressor is showing no signs of any of those symptoms.I also ran across this article:
it's important to note that on some cars, it's normal for the A/C compressor clutch to turn on and off during system operation. These types of cycling-clutch systems turn the compressor clutch on and off to regulate the flow of refrigerant into the evaporator. Since theses systems use a fixed orifice tube, it can't regulate refrigerant flow on its own. You can tell this type of system by a periodic clicking at the compressor clutch, as it turns on and off. Frequent clicking on and off of the compressor clutch, however, usually indicates a system that is low on refrigerant charge.
If there was a leak in my system,would'nt there be signs of the oil leakage also because Ive looked everywhere and I do not see any oil leakage anywhere.And How could I still be low on refrigerant after putting in 3 12oz cans of the R134a.I'm sorry,I'm new to this whole A/C thing.Like I said,I will have it checked tommorow for leaks and low refrigerant and everything else.
06-03-2008, 08:03 PM
#24
My Ride: shelby z
again, it has been awhile since I have done one of these changeovers, but-if you can get readings on low and high sides, it will probably be fairly easy to figure what needs to be done-
also, don't just check it while idling, drive it so that air is cooling the condenser, or at least run a garden hose in the front of the radiator to get an idea-can you measure the temp coming out of the vent? do you have the system set on 'max'? If you are getting 38-40 degrees, especially when driving, I would not worry about it too much-if higher, replace the orfice tube first (the filter)-it is almost always the problem, and that is also an indication of extremely high readings on the high side. like i said earlier, I am a little rusty on this stuff, so, (hopefully) others will jump in here-
06-03-2008, 08:40 PM
#26
The system uses a cycling clutch. when the low side reaches a pre-determined pressure(by low side cut off switch) the switch opens cutting power to the compressor, as the pressure rises the switch closes again completing the circuit to the compressor, that is how evaporator(low side) pressure is maintained.
In an A/C system pressure and temperature are directly related, if the low side dropped too low the evaporator would freeze.Our cars also use a thermal expansion valve that opens and closes to control the amount of refrigerant entering the evaporator.
Be sure you do not see any lines freezing, frost on a line indicates a restriction. Condensation is normal.
Also the molecular structure of R134A is smaller than R-12 so a small leak with R-12 will become a larger leak with R134A.
06-03-2008, 08:57 PM
#27
My Ride: Daytona
Engine: 2.2 liters
also no one mentioned a high pressure cut-out
r134a runs a lot higher head pressure then r12.....can get as high as 400-450psi easily.
the systems i work on have a high pressure cutout/fan cut in switches...usually cutting the fan in anywhere from 350-450 psi.
i recommend at least wiring in a pressure switch to cut the clutch out for when stopped in traffic. to prevent system damage. lack of air flow over the condesor causes the pressure to climb rapidly
06-03-2008, 09:04 PM
#28
Agreed, a lot of cars have had to have "pusher fans" installed to aid in condenser cooling especially on vehicles with small frontal grill areas.
