Old 06-03-2008, 11:54 PM   #31
Re: AC R-12 to R134a retrofitting
Our cars do not use an orifice tube, they use an expansion valve.Usually when they fail the low side will go into a vacuum, the compressor will be engaged and no cooling, we see it on Jeeps all the time.
The controller only controls the ground side of the A/C clutch relay and and will turn the relay off under high load conditions such as high boost, wot, etc. It should not affect the A/C at idle.
NAJ is online now
Old 06-05-2008, 08:12 PM   #32
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
Images: 2
Fun fun. Im going to be doing this this weekend. I had a couple of questions before going about this. Im going to pump down my compressor....anyway of checking to see if the compressor is bad before going any further? Another thing.....the oil. I read on here to only use Ester oil....do i need to do that when i pump down the compressor or do i just pump it down change the fittings and then pump in new refrigerant? If i need to add oil do i need to get all the old oil out and if so how? Temps here are getting into the 90s now and i cant go without a/c for another summer.
irocelectric93 is offline
Old 06-05-2008, 08:17 PM   #33
My Ride: Daytona
Engine: 2.2 liters
rule of thumb
for high side operating pressures is double ambient (F) temperature plus or minus 10%.
for low side operating pressure is 10% of high side pressure plus or minus 10%
also after reviewing the thread i've noticed nobodies talked about leak detection methods.
three methods are:
- electronic sniffers
-dye and UV light
-dry nitrogen and soapy water
my opinions..electronic sniffers are CRAP...dye and UV works good, and my favorite is dry nitrogen and soapy water, its inexpensive and faster.
Realest is offline
Mortgages | Mobile Phone | Mortgages | Credit Cards | The eBay Song
Page generated in 0.32718 seconds with 13 queries
