Old 06-05-2008, 05:10 PM   #1
Couple questions (Air Conditioning and Headlights)
Mitsu Booster
My Ride: 1988 Shelby Z
1988 Shelby Z
1. My Daytona has no air conditioning or signs of AC ever being in this car. What kind of hassle would it be to intstall an AC system?
2. Last night for unknown reasons my headlights would not go down unless I turned the dimmer to the right. And then my dash lights would stick on as well as all my side marker lights. I put in a new light/dimmer switch and the same thing... I pulled the fuse (I forget what it's for but it's numbered "5") and my lights work again.
Any idea what my problem is with my headlights? I would like to install the fuse again.
seriosbrad is offline
Old 06-06-2008, 01:06 AM   #2
Re: Couple questions (Air Conditioning and Headlights)
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
1. It's a bitch, but it can be done. Finding a whole donor car would be the best way.
2. Sounds like a bad ground or a short somewhere.
Sittn86 is offline
Old 06-06-2008, 05:37 PM   #3
Mitsu Booster
Ew, I'm suck at wiring problems this is going to suck big time trying to track it down.
Does anyone have a diagram of what the fuses control and where the wires go?
Old 06-07-2008, 07:07 AM   #4
Fuse # 5 is a 20 amp that powers the cluster at cavity #12, park/tail lamps, side marker/license lamps and electronic display intensity.
Your main problem seems to be that the headlamp doors would not close.
Start by testing (with a test light or voltmeter, be sure key is on and lights are on) ALL other fuses. It is possible that another fuse is blown and the headlamp control module is being fed by another circuit(fuse 5).
If needed I will post the wiring for the headlamp system.
Old 06-08-2008, 04:05 PM   #5
Mitsu Booster
NAJ,
Had a look over fuses and wires all morning and couldn't make any progress.
I would appreciate a diagram for headlights
Old 06-08-2008, 05:35 PM   #6
Refinance | Mortgage Calculator | Direct TV | Per Insurance | Literatura fantástica
Page generated in 0.31820 seconds with 13 queries
