Old 06-06-2008, 10:52 PM   #1
Rampage
My Ride: 1982 Dodge Rampage
Images: 1
I have a 1982 Dodge Rampage with a 2.2 L and a 4 speed manual trans. The engine has had a lot of work done to it including bored .40 over and ported polished balanced stroked and shaved head. My problem is I just replaced the plugs and put a msd pro coil on and now it has a sever miss. Any ideas?
johnny rampage is offline
Old 06-06-2008, 10:57 PM   #2
Re: Rampage
Feedback: (32)
Put the stock coil back in and see how it runs?
tryingbe is offline
Old 06-06-2008, 11:05 PM   #3
Re: Rampage
Images: 1
Thanks for the info I will get one tomorrow and try it. Does it have to muck spark at this time? At high RPM's it seemes not to have as much of a miss.
Old 06-06-2008, 11:22 PM   #4
Re: Rampage
My Ride: 95 Caravan
Could be a cracked plug or bad ignition wire also. The spark plugs porcelain insulator can get cracked if dropped. Pulling the wires off to install the plugs can break an end. Did you check the plug gap? How does the cap and rotor look? Increasing the spark can increase the chance of mis-firing.
turbo1168 is offline
Old 06-08-2008, 04:39 PM   #5
Re: Rampage
Images: 1
Thanks alot for the advice. I will be getting it taken care of tonight so it will be race ready for next weekend. Thanks again I hope to be posting pictures of everything im doing. I still havent picked paint yet. Im leaning toward Plum crazy purple and flat black or hemi green and flat black. Im also going toward the hemi cuda scheme. Any input would be taken into consideration. Big Thanks Again
Cadillac | Loans | Mortgage | Credit Card | Loans
Page generated in 0.32470 seconds with 13 queries
