Old 06-13-2008, 10:50 PM   #1
compresion drop, any ideas?
My Ride: 87 daytona shelby z
Engine: 2.2l turbo
Images: 3
ok so i posted a while ago about my 87 shelby Z TII... compresino readings were
1- 119
2-123
3-120
4-90
i finally got my buddys csx out of my garage and the daytona rolled in, pulled the engine and dissasembled it.. the headgasket was fine, it was sealed real well seeing as it was a PITA to rip the head off, none of the rings are broken, no holes or cracks in the pistons, and from what i can see, the valves all seat fine.. only thing i noticed is the infamous crack between the valve seats on cyl 2 and 4. anyone have any other ideas what could have happened?
Foxmxrcer is offline
Old 06-14-2008, 01:06 AM   #2
Re: compresion drop, any ideas?
My Ride: 84 Turbo Z, more
Engine: 2.2-2.5
Too late now but you should have leaked the engine before disassembling.Oiled the cyls for ring test.vac for valve leaks.difficult to diagnose now that it's apart.
4Daytonas is offline
Old 06-14-2008, 08:12 AM   #3
+1
Cylinder Leak Down test should have been done before disassembly.
Old 06-16-2008, 12:41 PM   #4
Feedback: (32)
Rebuild the engine while you have it apart.
tryingbe is offline
Old 06-16-2008, 10:37 PM   #5
+1. Have the head leak checked and valve grind / guides / resurface done. Check the block for taper and wear and a flat deck. Check the pistons for collapsing. Check rod pin bushing condition, etc. You in there after all.
IROCNOROLL is offline
Debt Help | MPAA | Bad Credit Mortgages | Credit Cards | Xecuter 3 Mod Chip
Page generated in 0.32206 seconds with 13 queries
