Old 06-22-2008, 08:32 PM   #1
87 GLHS Low Boost Pressure
My Ride: 1986 Shelby Charger
I just bought an 87 GLHS. The car looks great but doesn't run to good.
I can only get the turbo to give me 5 lbs of boost under full throttle. Then the car seems to develope a miss.
After I start cruising down the road a short piece it seems to run fine.
But the car has low boost and is short on power.
I checked the plugs and wires they seem ok.
Any Ideas what to look for?
Thanks,
hemicuda528 is offline
Old 06-24-2008, 01:49 AM   #2
Re: 87 GLHS Low Boost Pressure
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
Cycle the key 3 times without starting it & count the series of flashes. 55 is end of sequence. Do a tune-up, replace filters, change oil, visually inspect all the vacuum lines & report back with any codes you find with the above procedure . Oh, change the PCV valve, too.
Sittn86 is offline
Property in Spain | Online Loans | Credit Counseling | Loans | Loans
Page generated in 0.27785 seconds with 13 queries
