06-26-2008, 05:34 AM
Re: Not getting fuel, how do I track problem?
The ASD relay (part of the PM on your car) powers the fuel pump, injectors and + coil.
To check the ASD relay output and power to the pump locate the underhood diagnostic connector and with the key on/engine off ground the DB/YL wire, this will actuate the ASD relay so you can check power output to the pump and at the pump.
As seen in the pic term #6 of the 10 pin connector is the ASD power output so while the ASD is actuated backprobe that terminal with a test light or voltmeter and check for 12 volts, if ok check at the pump connector, if power is ok at the PM but not at the pump there is a wiring issue, if power is present at the pump and the ground is ok replace the pump. If power is not present at the PM then you need to check all of the power inputs to the PM. If power is missing at the PM there also will not be power at the + coil or the DG/BK wire at the injectors.
Reason: 1 image did not post
