06-27-2008, 10:53 AM
Re: 87 GLHS can I run it with the Wastgate Actuator disconnected?
My Ride: 1985 &86 Omni glhts'
Engine: 2.5 T2
As was stated earlier, it seems you have a leak in the tubing between the turbo/ intercooler/throttle body. Check the tubing and couplers for cracks/tears. Also make sure your clamps are tight. Also see if the vacuum nipple that screws into the intake is tight. What does your boost/vacuum gauge read at idle? If there's a vacuum leak, there's a spot where the intake charge will leak out under boost.
