Old 06-28-2008, 02:28 PM   #1
need an exhaust manifold ASAP
My Ride: Shelby Lancer #92
Hello all,
I'm in mid project trying to change an exhaust manifold gasket only to find that the studs that hold the turbo on are all stripped causing an exhaust leak. Of course all the studs snapped off upon removal so I need another. If ANYONE in the hancock county ohio area has a manifold laying around that they can spare I'll come get it. I really need my car for monday if at all possible. Call me if you have one.
John
419-957-0720
kuzman83 is offline
Old 06-28-2008, 02:39 PM   #2
Re: need an exhaust manifold ASAP
Feedback: (32)
I got all the parts you need, except I'm in AZ. Here's a free bump for you.
tryingbe is offline
Old 06-28-2008, 02:43 PM   #3
My Ride: 95 Caravan
Hopefully you can find a manifold local to you. If not replacing the studs will get you back on the road. If any part of the studs are still there (long enough to get vice grips onto), you might get lucky and be able to remove the studs. It will require a handheld torch, MAPP gas is hotter. Heat the area around the stud cherry red and then clamp the vice-grips on tightly to remove. If the studs broke off flush, it will require drilling and extracting.
turbo1168 is offline
Old 06-28-2008, 04:25 PM   #4
My Ride: 1999 Dakota
Engine: 5.2
left handed drill bits work pretty good too,they will drill out the stud & back them out when they bite
Ray Clifton is offline
Old 06-28-2008, 05:04 PM   #5
My Ride: 1989 Daytona ES
Engine: 2.5l Turbo
Feedback: (9)
Contact Turbomini, he may be able to help you out. He usually has some parts laying around.
1983Rampage is offline
Old 06-28-2008, 07:06 PM   #6
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
+1 on using a torch for heat. I use a small Oxy/MAPP setup as a matter of course when it comes to exhaust fasteners. Makes them come apart like they're buttered
Screamin4banger is offline
Old 06-28-2008, 07:32 PM   #7
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (9)
if nothing i have one here with a mild cleanup and port that has good studs ready to go if you wanted to buy it
xtrempickup is offline
Old 06-28-2008, 07:55 PM   #8
well... not what i was hoping for but i found a guy that has a machine shop and he's going to take them out for me. I was hoping i could get ahold of a guy named matt that lives in Van buren. I bought a head from him as he was getting out of the TD scene. Thanks for the responses I'll post the results good or bad tomorrow.
kuzman83 is offline
Old 06-28-2008, 08:37 PM   #9
then you might as well have him cut the flange while its there
Old 06-28-2008, 08:49 PM   #10
My Ride: shelby z
Mapp torch should be in any rodders garage-just have a fire extinguisher handy (trust me). ditto on the butter
mmtphoto is offline
Mortgages | 0 Credit Cards | Mobile Phone | Freelance | Personal Loans
Page generated in 0.55875 seconds with 13 queries
