06-30-2008, 09:16 PM
Re: Smells like melting wires
My Ride: 88J 94P 03dime
Engine: 2.2 in all of em
um the smell you may be experiencing would be burning rubber. have you ever done a smoking burnout before this? if you know what burning rubber smells like, the burning wire smell may be due to the fact that you did this on winter tires. they use a different compound than a performance or all season tire. different tires will have different smells, different sounds and different "patch" laying- eg; lays a strip with no noise, or squeals and lays no strip, or makes little noise and leave a little pile of rubber chunks behind the tire instead of a patch on the ground.
either way if you do a burnout enough to make smoke you can see while in the driver's seat , that smell wil be with the car for a day or 2. now if you keep getting that smell a few days later you might be on the verge of toasting something.
