Old 07-02-2008, 06:31 PM   #1
Code #62.....What Is It..???
My Ride: 92 Shadow ES
Engine: 2.5 T1
Getting a code #62,CODE 62 Unsuccessful attempt to update EMR mileage in the controller EEPROM.....
What the &%#$ does that mean...????....Have reset the comp,and after a couple good runs I get this error again...???
Anyone have any idea's...???
92 Shadow ES 2.5L TI 5-Speed with a super 60 turbo....
sickofit is offline
Old 07-03-2008, 05:00 PM   #2
Re: Code #62.....What Is It..???
Old 07-06-2008, 12:10 PM   #3
Engine: 2.5 T1
Thanks NAJ...!!!
I see at the top of the page it says to perform test DR-1 before proceeding...do you have a copy of that test as well...???
Thanks again...
sickofit is offline
Old 07-06-2008, 06:51 PM   #4
Test DR-1 is the "Checking System For Faults" test.
Be sure the battery is fully charged, does he DRB scan tool communicate with the system, start the car, warm to normal operating temp, raise rpm to 2000 for 10 seconds and return to idle,cycle the AC on/off , cycle thru all gears and return to park (Auto Trans) then with the DRB go to "Actuate Relays/Solenoids" start with the A/C Relay and then actuate all other relays/solenoids, exit the test and check for faults, any faults present?, go to specific fault and page for diagnostics.
SanDisk Flash Memory Card | Cheap Moissanite Earrings | Magazine Subscriptions | Credit Cards | Loans
Page generated in 0.29673 seconds with 13 queries
