Old 07-19-2008, 03:00 AM   #1
Smile 0 km 2.5l(turbo swapped tbi)-not staying timed
My Ride: 88 Shadow Es
Engine: 2.5 Swap
Ok as the situation has it i was blessed with a blown 2.2l turbo engine when i bought my car i was forced to swap my engine out(luckily I get dodge parts for next to nothing and a free brand spanking new 87 2.5l TBI block which i decided to put all my 2.2 turbo parts onto it except for the garret t1 turbo which ass the necessary accomodations were made to make it a turbo 2.5L spec .
1989 sundance 2.5L turbo 2 computer
2.2 wiring harness
1987 tbi 2.5 block
2.2L turbo cam with 2.2 cam gear
1988 distributer gear(i thought this might have been the problem that the teeth could have been slightly different on the 2.5L and the 2.2 but i verified they were the same when i ordered the 2.5 gear in
the only thing that was changed from the 2.2 gears was the gear that connects to the crankshaft which propels the belt this was replaced with a 1987 unit because the 88 2.2 wouldnt fit the shaft
now when this car is timed correctly for a short period of time it SCREAMMS(caps for max emphasis) but the car quickly runs itself out of time foward a few degrees, so my question is what could it be?is the 2.2 distributer different from the 2.5 one? is my 87 2.5 timign belt not correct?...if you need to know anymore things about the car to properly diagnose it I will respond immediatly thanks
-WILL
ShadowEs88 is offline
Old 07-19-2008, 03:39 AM   #2
Re: 0 km 2.5l(turbo swapped tbi)-not staying timed
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
you put the 2.2 turbo reciprocating assembly (crank, rods, pistons) in a 2.5 tall-deck block?
This is what you are saying?
Whatever...
If you only care about losing time... you shouldn't have a problem if you used the gears and belt from the 2.5... make sure that the cam gear and i-shaft gear are absolutely identical. Use a 2.5 crank gear too.
I prolly would have thought about having the machine shop deck the F outta that block to give it the 2.2's deck height.
Screamin4banger is offline
Old 07-19-2008, 08:31 PM   #3
Engine: 2.5 Swap
no no its all 2.5 gear in the engine
Old 07-19-2008, 08:50 PM   #4
What do you mean by "runs itself out of time foward a few degrees"? Cam timing? Ignition timing? How are you measuring this? Also, what is a "short period of time"? If you can explain whether you are talking about cam timing or ignition timing, as well as how you are measuring the change in timing, you will be much closer to getting an answer.
william is offline
Old 07-19-2008, 08:55 PM   #5
TurboDodge.com Admin
moparfwdsleeper's Avatar
My Ride: 87 CSX & 85 GLH
Engine: 2.2TII & 2.5N/A
Feedback: (29)
Images: 166
broken I-shaft or oil pump gear?
-Clayton Dennis ~ Forum Admin
1987 Shelby CSX #674
1985 Dodge Omni GLH - Parting Out, PM me!
moparfwdsleeper is offline
Old 07-19-2008, 08:57 PM   #6
I had one of these go, what a maddening thing to diagnose the first time.
william is offline
Old 07-20-2008, 04:53 PM   #7
Engine: 2.5 Swap
ok well, when i set the timing up with the cam how its supposed to be and the (distributor pully?) and the cranksahft pully correct,then throw the belt on, i set the timign to 12 degrees advanced or whatever its supposed to be cant remember exactly right now,but it will advance within a minute to 13,14, degrees advance and begins detonating harsh
Old 07-20-2008, 05:02 PM   #8
Well, this seems obvious. 1987 crank pulleys were square tooth. All 1988 and newer engines have round tooths. So are you mixing?
22dodge is offline
Debt Consolidation | Credit Cards | News | Loans | SanDisk Flash Memory Card
Page generated in 0.32201 seconds with 13 queries
