Old 07-20-2008, 02:44 AM   #1
Exclamation how to remove axles? pulling engine/trans together, need help!
My Ride: 1992 Daytona Iroc
Engine: 2.5L T1
Okay, so I have a 1993 Daytona (2.5L TBI/5spd A523) that I need to pull the engine and tranny out of...
I have removed the engine by itself in these cars before, but I would like to know the best way to disconnect the drive axles so that I can remove the engine and transmission and engine together.
Any advice?
zer0321 is offline
Old 07-20-2008, 07:01 AM   #2
Re: how to remove axles? pulling engine/trans together, need help!
I'm not sure if it is the best way, but I usually pop the lower ball joint. That way it has minimal impact on alignment when you reassemble the car.
william is offline
Old 07-20-2008, 07:37 AM   #3
My Ride: 92 Iroc R/T Red
Engine: TIII
remove the big axle nut something like a 32 MM remove the sway bar mounts on both lower control arms and just loosen the frame mount sway bar bushings. (this lets you pry the lower ball joints apart easier) remove the pinch bolt of the lower ball joint and pry the knuckle off the ball joint stud. To get the axle out from here is easy. I turn the steering wheel right to take out the left side axle and left to get the right side out. turning the wheel lets you have more room to pull the strut spindle assy out farther to pop the outer cv out of the bearing hub. once the bearing hub is clear pop the inner joint out of the trans. don't pull on the shaft to do this the shaft could pull apart. use a pry bar and pop it from the back of the inner joint. Have a pan near by trans oil will usually come out when you pull the shaft. Pull both and the engine trans should come out ok for you.
Tim
charger R/T is offline
Old 07-20-2008, 09:04 AM   #4
My Ride: 88 c1500 Lowrider
Engine: 305
Feedback: (7)
Very good Info , it is easier to prevent a mess than it is to clean one up !!
shadetreeshop is offline
Old 07-20-2008, 09:17 AM   #5
Any advice?
The BEST method it to get a shop manual at RTFB.
You could take a torch or sawzall and cut the shafts in the middle, then the inner joint will stay in the trans so you don't loose fluid and make a mess. This also allows the outer joint to stay in the hub so you can roll the car around and not have the bearing fall apart.
22dodge is offline
Old 07-20-2008, 09:23 AM   #6
My Ride: 86 Laser XT
Engine: 2.2 turbo
Images: 2
^thats only if he doesn't want to reuse the drive axles
Old 07-20-2008, 09:34 AM   #7
Feedback: (32)
[IMG]http://www.************.net/tryingbe/dodge/Daytonaproject/engientranny3.jpg[/IMG]
tryingbe is offline
Old 07-20-2008, 09:36 AM   #8
Engine: 2.2 turbo
Images: 2
How many times have you posted a pic of that car as a guide to pull motor and tranny out the bottom?
Old 07-20-2008, 01:43 PM   #9
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
I think that is how tryingbe changes the oil too, takes engine out removes filler cap and turns engine upside down to pour the oil out.
dyno sheet
fmic install:
crazymadbastard is offline
Old 07-20-2008, 03:37 PM   #10
Engine: 305
Feedback: (7)
I Get a good laugh when I see a motor that "Usually" come out from the top , Laying on the ground .
Thanks for the good belly laugh !
Credit Cards | Personal Finance | Remortgages | Loans | Online advertising
Page generated in 0.36796 seconds with 13 queries
