07-22-2008, 11:22 PM
#17
Re: Piston Questions
My Ride: 88J 94P 03dime
Engine: 2.2 in all of em
fwdperfromance sells singles, and they are mahles- same thing you got in there. id consider getting a new set of rings while you're at it, break the glaze on all 4 cylinders and pop the pistons in with a new set of rings. otherwise you'll have uneven compression. wont really hurt it to just do one piston and ring, but if they previous owner was runing high boost and it led to a cracked piston, the rings might not be in too good of shape to begin with. its just as easy to do a re-ring on all 4 cylinders as it is on 1
