07-24-2008, 04:50 PM
Re: Burning Oil, Possibly because I'm Running Rich? Help
1 qt every 200 miles with blue smoke, that is severe.
Since you have access to air remove the valve cover remove the rocker arms on # 3 cylinder, put air in the cylinder and remove the valve springs and take a good look at those valve seals.
Oil rings will not affect compression.
07-24-2008, 05:08 PM
My Ride: 86 Omni GLHS
I do not know how to post pics
I have some on the cardomain website
As for the hook-up I'm not sure. The PCV gets rid of the pressure?
You can just see it in the pic, but not visible it's hooked up the a cone filter .
Thanks again
http://www.cardomain.com/ride/2577091
07-24-2008, 07:40 PM
My Ride: Turbo Z
If it was a turbo seal problem,it would smoke white,and as soon as you started the engine.After it warms up maybe valve guides along with valve seals.
07-24-2008, 11:12 PM
My Ride: Turbo Z
It's called BLOW BY.The best way to get the turbo off is to take the head off.If you're not sure about the valve seals or guides,take it to you nearest machine shop.Prob not the turbo's fault!
07-24-2008, 11:24 PM
#12
I agree, if the problem was PCV or Turbo related it would probably affect all 4 cylinders not just #3 cylinder.
07-25-2008, 11:04 AM
#14
Fool proof method? Rebuild the engine and rebuild the turbo.
But if only your third cylinder is getting oil, your piston or rings in the 3rd cylinder are gone, most likely.
It's completely normal to have shaft play in the turbo. Though, I have a near NOS condition turbo if you're considering upgrade/new one
Near NOS condition, 89 TII Garrett with 2.5 inch swing and big wastegate actuator
There is only one place oil can come into the inlet of the turbo, that's the PCV system. Factory PCV system is known to let oil into your intake system very easily.
07-25-2008, 12:29 PM
#15
My Ride: 86 Laser XT
Engine: 2.2 turbo
How about you run a compression test on the car for kicks before you decide to tear it down.
That will forsure narrow down that cylinder 3 has ring issues.
Also it will gauge where the rest of the motor is at as well.
Rebuilding the turbo, head, and motor sounds like a total solution to your problem.
