08-08-2008, 02:01 AM
Re: xtremely rough running , timing off?
Politically Incorrect
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
This is for CHECKING cam timing. if it needs to be adjusted you'll still have to tear stuff apart.
The lazy man's way: (i've never seen this posted)
- Disconnect battery!
remove the #1 spark plug and put something in that is stiff, soft, and durable - like a plastic drinking straw.
Crank the engine by hand from the crank pulley with a long extension and breaker bar. (13mm I think) through that hole in the splash shield untile the plastic straw goes as high as its going to go. that should top dead center. go over to the bell housing to verify that the timing mark is right at 0. make adjustments until its at zero and proceed.
now pull the distributer. the slot in the oil pump shoul be oriented left to right PERFECTLY. when re-installing, make sure rotor is pointing toward #1.
now up top, pull that little plug out (maybe its gone already) of the plastic belt cover. Slide something like that soda straw in the hole and make sure the hole on the cover lines up perfectly with the hole in the cam gear.
if anything is not lined up perfectly like I just described above, its time to start taking pulleys off and looking for dots on gears.
EDIT: if when pulling distributer you notice rotor pointin to #4, engine might be at TDC on exhaust stroke... spin motor around by hand until you are TDC on compression stroke.
Click Here: I need a 2DR L-Body REAR Bumper Mount
My Mopars:
85 Shelby Charger - Garnet Red/Silver <- 100% Rust-free - Beautiful one day
86 Shelby Charger - Black/Silver <- $150 Rust-bucket Beater
73 Charger SE - Gold/White top <- Rust-free - will be MS & TT eventually
91 Spirit R/T - White <- Sacrifice to the L-Body Gods
