08-16-2008, 12:56 PM
#16
Re: running extremely rich
My Ride: 06 ram2500, 85 dodge
yea it's an automatic. when it was hooked up to the scanner i did run all the tests it had, but it was a month ago, so i dont particularly remember the IAS test. i just remember that every test i did i could hear actuators working. fuel pressure was checked and it was right at 53psi. all the vacuum lines seemed to be in ok condition and routed correctly. the lines to the baro sol are correct as well. when running if i unplug one of the sensors from the dist pickup it does nothing, the other kills the engine immediately. should they both have an effect at idle, if unplugged? im leaning towards your idea of eliminating all the crap under the hood. thanks, again.
