08-15-2008, 06:40 PM
Re: 90 VNT engine cutout
First be sure of connector terminal integrity, loose connections will cause the problem you are describing. Also if you bent the wiring from the HEP down the side of the distributor as the factory had it you probably damaged the internal wiring, this is experiance and being stranded talking.
If none of this corrects your problem let me know and I will post the diagnostics for you.
08-18-2008, 09:22 PM
If the terminal is not broken just be sure they are making a good, tight, secure connection. A little silicone dielectric compound in the connector will prevent future corrosion.
I have never seen pigtails for the HEP connectors and the terminals themselves would have to be matched up and there are hundreds of different terminals used.
09-07-2008, 02:22 PM
It is very possible you have a bad HEP, some people have had good luck with aftermarket HEP's but we generally recommend Mopar.
Some things to keep in mind, check for corrosion or poor fitting connectors/terminals.
Also do not bend the wiring down the side of the distributor as the factory had it or internal wire damage may occur.
Your procedure for replacing the controller is correct, disconnect the battery, remove connector, remove controller.
While the connector is unplugged check the terminals for corrosion, you may want to use an electrical contact cleaner.Corrosion will not look like battery corrosion, it will be darkened spots on the terminals in the controller and connector. Spray the connector/controller terminals then plug/unplug a few times and spray again and repeat, this will remove the tarnish/ corrosion.If you have access to compressed air it is best to blow the connector out with air when done.
09-29-2008, 06:26 PM
The car just shut off while driving or when on decel when coming to a stop?
09-29-2008, 06:28 PM
MEOW!
My Ride: 87shelby charger
Engine: 2.2L TII
i'm gonna ad this in here. did you check the connector by the battery tray? it might be getting lose.
09-29-2008, 07:28 PM
My Ride: 90 Vnt Comp. Shadow
Engine: 2.2 Turbo IV
This has nothing to do with any codes you are getting, but I have had a similar problem and it was a bad fuel pump. It would stop working after driving for a while then it would start right back up, randomly. Drove me nuts. Just an idea.
09-29-2008, 11:56 PM
#13
Code 25 is "A Shorted Condition Detected in One or More of the AIS Motor Circuits"
That does not mean a faulty AIS.
It is possible that any "short circuit" can create your problem depending where the short is located.
Clear the code,verify the code is cleared, drive the car, recheck codes. If the code 25 returns run the diagnostics.
