Old 08-19-2008, 09:37 PM   #1
Engine swap
My Ride: 83 Dodge Rampage
I've got an 89 2.2 turbo Lebaron with a cracked block and lots of bad noises. I've also got an 88 Horizon parts car with a good 2.2 fuel injected motor. Is there any reason I can't pull the intake and exhaust manifolds, and the distributor off the Lebaron motor, put them on the Horizon motor, and drop it back into the Lebaron?
dragonslayer is offline
Old 08-20-2008, 02:06 AM   #2
Re: Engine swap
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
You'll blow it up pretty quickly. Turbo exhaust valves are made of a different material, the pistons are flat for a lower compression ratio, N/A motors don't have an oil drainback tube for the turbo......... So, yeah, I guess there's a reason it won't work.
Sittn86 is offline
Northern Rock | Refinance | Mortgage Loans | Advertising | Credit Cards
Page generated in 0.43374 seconds with 13 queries
