09-12-2008, 05:06 PM
#20
Re: help mee
My Ride: 89+90 Daytona Shelby
Engine: 2.2 TII, 2.5 TI
For a Daytona, you can use any K variant axle from '87 up. So, LeBaron, Daytona, Shadow, Reliant, Spirit, and all their stablemates. L body (Omni, Charger, Rampage) will not work, nor will a Minivan. There is no difference between turbo and non-turbo axles. You can even use the V6 axles. The only difference was on T2 cars, most of them had the equal-length setup. If you set your suspension and weight correctly over the tires, the unequal-length won't torque steer any worse than the equal-length setup. I'm not making huge power on my 2 Daytonas, but 1 has equal-length and the other unequal. Neither torque steers very badly, nor does one feel worse than the other.
